Now that you've cleaned the old junk out, get some common chassis grease or cornhead grease and:
7. Begin reassembling, greasing the sliding detent rod. (image one below) 8. Be certain to grease the bottom and sliding sides of the bakelite piece. (image two below) 9. Install the bakelite piece over the sliding detent rod and then angle the greased rod clip in as shown. (image three below) 10. Install the three small springs. (image four below) 11. Set the contactor and fiberglass plate below it in place. (image five below)
And now, please follow to next post...
