9 members (48ed56pam, Gabes-trucks, keith, 52Carl, Gdads51, Steelonsteel, dt235sd, J Lucas, 1 invisible),
250
0
Mod | | | Forums66 Topics128,081 Posts1,056,075 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 23 | The original eaton had the spring perches equally spaced from the center line of the pinion. I need to move the perches over by half inch to get the same measurement on the 14 bolt, therefore the spring perches will still be 41.5 inches apart but not equally spaced from the WMS or rotor or whatever point on the outer end of the axle you measure from. | | |
