It's good he has a WW. I used the 305 to get the PSI value for an electric FP he is contemplating. I have a WW on my 305 V6. Good carb as you say. BTW Jon, there was a soft "fiber" "washer" almost like felt, that I put on the Acc Pump rod. I thought is was to seal the hole. I put it on the outside of carb, maybe it goes on the inside? Or where does it go? What is it?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn |
