| | | Forums66 Topics128,089 Posts1,056,005 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Today, my son and I were planning to install a new fuel gauge sender for an eventual install of some New Vintage gauges on his '52 1/2 ton panel. We got the tank partially out but the filler neck on the tank got hung up on the frame. Does anyone have any tips for getting the gas tank out of a 1/2 ton panel? It looked like if I removed the driveshaft it would give more movement away from the frame and allow for the neck to clear the frame. We put everything back together with no leaks but now it won't start. (Heading over to the HiPo forum for help with that.) Thanks in advance.
It's a small world, but I wouldn't want to paint it.
