4 members (Wally / Montana, HandyAndy, FAST55, J Lucas), 49 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#1362387 05/28/2020 6:33 AM
Today, my son and I were planning to install a new fuel gauge sender for an eventual install of some New Vintage gauges on his '52 1/2 ton panel. We got the tank partially out but the filler neck on the tank got hung up on the frame. Does anyone have any tips for getting the gas tank out of a 1/2 ton panel? It looked like if I removed the driveshaft it would give more movement away from the frame and allow for the neck to clear the frame. We put everything back together with no leaks but now it won't start. (Heading over to the HiPo forum for help with that.) Thanks in advance.
It's a small world, but I wouldn't want to paint it.
I think you answered your own question :-)
1951 Chevy Panel Truck
Are you trying to remove the tank with the filler neck attached?
Loosen the clamps on the rubber hose in between the filler neck and the neck of the tank.
It should drop out without the filler neck attached, mine will on my 1951 suburban.
Tim
1951 3100 Chevrolet
Tim, I disconnected the filler neck from the tank.
