My truck has a non original rear bumper that was welded on to the frame. I am using the bare spot on the bumper brackets (where I had removed the old tail ight brackets by grinding) as my ground. The ground strap from the battery to the frame was also cleaned so I am reasonably sure I am getting a good ground. And am using new lights.
