| | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13612 02/16/2003 2:18 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | The water is about 1 -1/2" below top. Strange that even though I've been complaining about leaking, the level hasn't really changed. Yes it might be the overflow tube, thus I have hooked the tube to a clear plastic bottle (kinda like an overflow container) to see if I suddenly quit seeing water on the ground as well as on the lower radiator frame that bolts to the front engine cross member which also shows moisture. The container has a couple very small holes so the overflow moisture will fill into it without any resistant.It may very well be the overflow tube since it was pointed down towards the lower radiator cross frame member.
Tim, you say for a '50 that the radiator cap should be a zero lb pressure cap ? The one I have current is marked at 7 lb. Hmmmmm. What impact could this have ?
cmayna
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
