| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Doesn't that fill plug have a simple pipe thread? I believe a vent might be a good idea to prevent pressure buildup inside the box from pushing lubricant past the seals when the under hood temperature gets high, but I'd suggest drilling intersecting holes at right angles, with the hole to the atmosphere coming in from the side. Jerry
