8 members (David Bush, Wally / Montana, GRNHydra, Oswald, Guitplayer, NJC, Otto Skorzeny, 2-Ton),
91
2
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | What condition are the front cab supports on both sides? Same for the floor boards! If they are sound, I would suggest that you remove the rear shackles and place 3/4" boards between the rear cab and the frame near where the shackles belong. Then add shims on the front mount which is light in the loafers until the the two mounts have the same amount of cab weight on them. Tighten the front cab mount bolts. Now install the rear shackles and remove the boards. The cab should now sit level. If not, then there is something wrong with one or the other of them or their mounting holes in the frame.
