I have a 235 mid 50s era engine block with the pistons seized in the bore. Also, over 45 years sitting in a farmers field, in the truck, apparently condensation from the head's intake/exhaust area leaked down along the bore, the piston rings and seized one piston with that, the other pistons are also seized. Last year I tried all the recommendations regarding freeing all the pistons up, found here and elsewhere on the web and nothing worked. I ended up finding another engine.
Question: Is this engine worth anything more than taking it to the scrapper?
'49 3100 "Sweet Caroline" because the truck has fabulous curves .... like Caroline!
