I hadn't thought of a speedy sleeve, I used one successfully on the rear axle pinion shaft. Now I'll have to decide if I want to "do it right" with some extra work or try the seal with the "cleaned up" crank surface.
Harold Wilson
41 Chevy 3/4 Ton
