Thanks Fla54 and Lonnie,
Lon...I checked out your "mock-up" picture. That is alot of tire stuffed in there! I helps to give me some perspective by seeing that.
Fla54...You brought up a good point...What I choose I must live with ...I am not going to keep swapping out wheels and tires. That being said...I am running the 6 lug stock set-up and that may not be in the trucks future. I will probably update the drivetrain in the next few years so I better not spend a ton of dough now if all I want to do is just get the thing rolling on the road for now. What started out as simply getting some different wheels and tire for the truck blossomed into trick wheels and tires. Geezzz! ha ha
