| | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Clark - there's nothing you'll put in that can't be handled by the stock rad - works fine for my 283, with 327's I've had, and the 350 my buddy's got in his 56 panel - the V8 is too far back from the rad, so if you can't shift the rad position the way GM did with a V8, you'll need a shroud
your alternative is to measure things up and head to a wreckers to find something close, but keep in mind that the OEM rad core support is what holds the front sheet metal together in alignment and mounts it to the front of the frame
Bill | | |
