9 members (rfs56trk, 50Chevy3100, 3800GUY, cmayna, Donf, Barry Martak, Peggy M, Lightholder's Dad, 1 invisible),
117
2
Mod | | | Forums66 Topics128,092 Posts1,056,461 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | Are you planning to mount the master cylinder on the frame or the firewall? A firewall mount is going to need some bracing to prevent the firewall from flexing when you step on the brake. If you're planning to use a swing pedal, the pedal bracket will also have to be mounted on a reinforced pivot. If those things aren't addressed during the buildup, the first panic stop will be interesting, and not in a good way. Jerry
