| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | Since the amperage load during cranking drops the battery voltage somewhat, the bypass wire allows the coil to get approximately the same voltage while cranking as it does during normal running through the resistor. That's somewhere in the neighborhood of 9.5-10 volts, which assures a good spark while the starter is running. Jerry
