7 members (Hotrod Lincoln, 46 Texaco, tclederman, papas52, dt235sd, MNSmith, 55shaker),
133
0
Mod | | | Forums66 Topics128,162 Posts1,056,913 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | Someone has added the second battery box under the hood, probably to improve cranking due to poor connections or too-small battery cables. It's also possible they left the under-floor box empty. Are the cable clamps under the floor insulated, maybe with tape or some other way of preventing the hot cable from shorting out? If the under hood battery box is big enough, a battery bigger than the Group 1 under the floorboard with more cranking amps might have been used. Jerry
