| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 123 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 123 | I've change the coil, distributor on the 54 chevy pu. i have aligned the timing mark on the flywheel with the pointer. i have spark at all the plugs. i think i have the plug wires coming from the distributo correct with the firing order. any suggestion for getting the engine running. it did run fine before i removed all the engine external components to paint the engine and under hood. where do you recomment the fiming mark be. how about the vacuum spark advance be set. i currently have is set at the mid point. Any help will be appreciated. Frank | | |
