Hi Carl, Can the bed be removed with the wood still attached?
I'm not Carl (and happy about that
) but I'm pretty sure you CAN'T remove the bed and leave the wood behind. Each board is attached ABOVE the bed steel at front and back, and at the sides is tucked UNDER the bedside angles.
