hello , i have a 1.5 ton chevy dually with a dana 70HD rear end with disc brakes and a sm 465 standard transmission . i have been searching for some type of emergency brake
to fit this set up . for the disc brakes my rotors are to thick 1 1/2 inch thick and the current calipers do not come with emergency brakes available , nothing i have found will fit . a
transmission brake , i have not found one yet . currently i have a
hydraulic parking brake i am not to crazy about . what about a pinion emergency brake ? and what type of emergency brake is excepted for general road use in all the USA ?
thank you 1pete1
