| | | Forums66 Topics128,190 Posts1,057,339 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 2 Moderated | | Moderated Joined: Nov 2019 Posts: 2 | All,
I rebuilt my 1949 Chevy Truck Carburetor (Carter W-1) that did not run in ~ 5 years. I removed lots of rust and gunk; I clean it using carb cleaner. After I put it back together and installed it ran good for a bit and it started to spilling gasoline thru the metering rod housing. I took it apart again put it back together and it is doing the same thing. I’m no mechanic but I know how to follow instructions. Any ideas what can be causing this? | | |
