3 members (jay d, 2 invisible),
54
3
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | You can tell for sure by simply unbolting the starter. A 6V starter will have a shaft diameter of 5/8", and when you push the shift lever to engage the drive gear, the gear will move straight ahead. 12V starters have a 1/2" diameter shaft, and the gear rotates slightly as it engages due to angled drive lugs on the armature and the drive unit. This minimizes the possibility of gear teeth failing to mesh when the starter pedal is pushed. If you're working with a car starter rather than a truck (which you've carefully forgotten to mention) the solenoid on a key-start 6V starter is bolted onto the starter housing rather than being cast into the nose cone. Jerry
