| | | Forums66 Topics128,141 Posts1,056,487 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,820 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,820 | The Melling M-45 is virtually a bolt-in swap. It's the same one that fits the 235 engine, and only requires a bit of creative plumbing to connect the inlet and outlet tubing. I'm working on an adapter to fit a small block V8 oil pump (Melling M-55) to stovebolt inlines, including the 216, which will supply about 30% more volume than the M-45. Jerry
