9 members (wilbur53, KEVINSKI, Wayne67vert, Lostbuthaulinass, Otto Skorzeny, 1955 1 Series, Peggy M, tclederman, 1 invisible),
104
Mod | | | Forums66 Topics128,142 Posts1,056,478 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 72 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 72 | Anyone have the volume specs for M11 and M29 oil pumps?
Thanks.
Larry
46 Chevy 1/2 ton stake - family truck for 78 years USAF 75-81
| | | | | Joined: Feb 2004 Posts: 29,819 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | Which engine do they fit? Bearing clearances and the condition of the crankshaft have a lot more to do with oil pressure than a specific pump volume does. Are you experiencing low oil pressure? In 60+ years of doing professional engine work, I've seen exactly two oil pump failures, and very few worn out pumps. Those were usually caused by the pump ingesting metallic particles which scored the housings and damaged the gears. Pump volume is directly proportional to engine RPM. Jerry
| | | | | Joined: Jan 2006 Posts: 72 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 72 | I'm building a full pressure 216 with a full flow oil filter.
Larry
| | | | | Joined: Feb 2004 Posts: 29,819 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,819 | The Melling M-45 is virtually a bolt-in swap. It's the same one that fits the 235 engine, and only requires a bit of creative plumbing to connect the inlet and outlet tubing. I'm working on an adapter to fit a small block V8 oil pump (Melling M-55) to stovebolt inlines, including the 216, which will supply about 30% more volume than the M-45. Jerry
| | | | | Joined: Jan 2006 Posts: 72 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 72 | Thanks Jerry. I'll check out the M-45.
Larry
