| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,942 | Since you've got a slight spiral engraved into the hole already, I'd suggest using red LocTite on the perimeter of the plug instead of some sort of flexible sealer. That will assure that the plug stays snug, and doesn't leak. Jerry
