2 members (Tony292, baldeagle),
32
3
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I respectfully disagree with using the factory timing spec. Fuel octane was MUCH lower when those specs were written. I haven't used a timing light in years. Start your truck, let it warm up then adjust to the fastest/smoothest idle, lock it down then readjust your idle. If needed you can fine tune using the octane selector but that likely won't be necessary. If your truck doesn't ping under load or drag the starter from being advanced too far you're good to go.
