9 members (UtahYork, Pre '68 Dave, rfs56trk, Donf, Oldcaliforniakid, baldeagle, J Lucas, Nick in Manitou, Rusted Nut),
36
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,005 Posts1,055,253 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | After installing a Langdon HEI distributor in my 1959 261 it started almost immediately, ran for 1 minute or less, quit, and would not restart. The culprit is 3 broken teeth on the distributor drive gear. I plan to contact Ton Langdon Monday. In the meantime I was hoping you guys could give me some insight as to what may have caused the broken gear teeth. Also, I know I have to, at a minimum, pull the oil pan and remove gear debris. What else should I do, other than hope I haven't ruined a very expensive engine?
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
