Just finally picking through the to do list on the project truck and the gauges are next. Got speedo working well and gas gauge and oil pressure all set...... but i could have swore the temp gauge had a cut capillary tube but i was wrong! Its a electric gauge. Does anyone know what the oem resistance values were for the stock sender? The gauge seems fine but with all the research i have done i keep getting totally conflicting info. Any insight on this would be greatly helpful. **** im not concerned with the thread size or where it goes because this is a custom setup but i just need to figure out the factory resistance values***
Thank you.
