| | | Forums66 Topics128,278 Posts1,058,581 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | This is not the end of the world. Don't sell the truck and don't take the engine out and take it to a shop.
I have pulled and replaced aluminum timing gears for the purpose of installing offset keys without pulling the cam out of the engine. If you get the aluminum gear good and hot and use oven mitts and are quick about it you should not have to bang on anything.
BUT
Since the gear failed with the engine running, a crank counterweight (or maybe its a rod, I forget which) likely wiped out a cam lobe. The clearances are that tight. The cam must be timed with the crank for the cam lobes to miss the crank. If it didn't catch a cam lobe, you just got lucky. You can check by pulling all the lifters and watching the cam go round and round through the lifter bores. This is less work than pulling the grill on a rusty AD. Don't know about a Task Force.
You might get lucky in the bent valve department too because when the gear starts to strip, the valve timing retards enough that the intake valves will start opening with the piston well into the down stroke and it will quit running altogether shortly thereafter. The exhaust valves are not a problem. When this happened to me it did no valve damage but I had to replace the cam.
BTW
There is a separate part number for timing gears for trucks vs cars. The truck ones are aluminum, the car ones are fiber, which run quieter. Don't replace the fiber gear with another fiber gear. Get an aluminum one. Fiber ones fail in trucks. Of course, use Hot Rod's method of checking for oil flow to the gear. Also, pull the pan and clean all the shreaded gear pieces out of the oil pump pickup screen and anywhere else you find them.
Make sure you get the timing marks lined up properly because you don't get a second chance after the gear cools. IF the timing marks aren't lined up you'll have to get out your puller and start over. Also, when you change the crank gear make sure not to get it on backwards with the timing marks on the back. I did this on an IH inline six one time and horror of horrors, the bolt holes for pulling the gear were blind and with the gear on backwards there was no way to get it off. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | |
Entire Thread
My 235 revved, died, won't start, and no coil fire or rotor spin.
| showme | 09/04/2019 10:02 PM |
Re: My 235 revved, died and won't start now. What's my next step??
| MikeE | 09/04/2019 11:40 PM |
| Hotrod Lincoln | 09/05/2019 12:02 AM |
| 03marauderman | 09/05/2019 12:12 AM |
| showme | 09/05/2019 2:45 AM |
| showme | 09/05/2019 2:55 PM |
| showme | 09/05/2019 9:22 PM |
| glenns towing | 09/05/2019 10:31 PM |
| TUTS 59 | 09/06/2019 12:52 AM |
| 52Carl | 09/06/2019 1:28 AM |
| showme | 09/06/2019 1:56 AM |
| Hotrod Lincoln | 09/06/2019 6:24 AM |
| showme | 09/06/2019 3:42 PM |
| showme | 09/06/2019 5:26 PM |
| Justhorsenround | 09/06/2019 5:33 PM |
| Hotrod Lincoln | 09/06/2019 6:34 PM |
| Gord&Fran | 09/06/2019 7:56 PM |
| 03marauderman | 09/06/2019 9:59 PM |
| EdPruss | 09/06/2019 10:07 PM |
| 52Carl | 09/07/2019 1:06 AM |
| MikeE | 09/07/2019 1:06 PM |
| glenns towing | 09/07/2019 1:26 PM |
| showme | 09/07/2019 2:49 PM |
| Hotrod Lincoln | 09/07/2019 3:06 PM |
| 03marauderman | 09/07/2019 8:13 PM |
| glenns towing | 09/07/2019 10:20 PM |
| 03marauderman | 09/07/2019 11:57 PM |
Re: My 235 revved, died, won't start, and no coil fire or rotor spin.
| HandyAndy | 09/11/2019 12:32 AM |
| TUTS 59 | 09/11/2019 1:05 AM |
| Greg_H | 09/11/2019 1:13 AM |
| Thrifty51 | 09/13/2019 2:50 AM |
| 52Carl | 09/13/2019 5:30 AM |
| Thrifty51 | 09/13/2019 1:13 PM |
| showme | 09/13/2019 12:21 PM |
| showme | 09/14/2019 12:40 AM |
| Hotrod Lincoln | 09/14/2019 1:18 AM |
| 1Ton_tommy | 09/14/2019 5:20 AM |
| HandyAndy | 11/09/2019 6:23 PM |
| dbwr | 11/09/2019 9:16 PM |
| showme | 11/10/2019 1:49 PM | |
