1 members (NofoolN),
125
Mod | | | Forums66 Topics128,186 Posts1,057,317 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | I see two glaring errors- - - -there's not enough threaded stud sticking out of the hub to attach the wheel securely, and there's a big gap between the center hole of the drum and the shoulder of the hub. There's no way that drum is going to run concentric with the hub with nothing but sloppy lug bolt holes trying to center it. Check the back side of the hub flange and see if there's a shoulder that will center up the drum correctly, and then buy some longer wheel studs to attach the drum to the back side of the new hub. Jerry
Entire Thread
Felt smart for 1 min, and then "Oh Man!, What?"
| OhioSteve | 09/04/2019 2:55 AM |
Re: Felt smart for 1 min, and then "Oh Man!, What?"
| Hotrod Lincoln | 09/04/2019 3:18 AM |
| OhioSteve | 09/04/2019 3:42 AM |
| Detroit Iron | 09/04/2019 7:25 AM |
| 52Carl | 09/04/2019 5:46 PM |
| OhioSteve | 09/04/2019 6:01 PM |
| OhioSteve | 09/04/2019 10:36 PM |
| Hotrod Lincoln | 09/05/2019 3:11 AM |
| OhioSteve | 09/05/2019 3:31 AM |
| Hotrod Lincoln | 09/05/2019 10:17 AM |
| showkey | 09/05/2019 12:23 PM |
| Phak1 | 09/05/2019 1:29 PM |
| OhioSteve | 09/05/2019 2:01 PM |
| OhioSteve | 09/05/2019 2:23 PM |
| Phak1 | 09/05/2019 3:20 PM |
| OhioSteve | 09/05/2019 9:34 PM |
| showkey | 09/05/2019 9:39 PM |
| OhioSteve | 09/05/2019 11:09 PM |
| 52Carl | 09/06/2019 1:49 AM |
| OhioSteve | 09/06/2019 2:33 AM |
| showkey | 09/06/2019 12:36 PM |
| OhioSteve | 09/06/2019 6:06 PM |
| OhioSteve | 09/07/2019 1:33 AM | |
