I am installing a complete new wiring harness in my 1954 Chevrolet 1/2 Ton. (Part# 52-025 from Classic Parts) So far so good, but now trying to figure out how to wire the tail lamps. Need to figure out how to hook up the new harness to the tail lamps. The new harness going to the tail lamps has 4 wires. Purple Wire(10) for "Tail Lamps", Pink Wire(31) for "Left Turn Signal", Purple Wire(32) "Right Turn Signal", and White Wire(22) for "Stop Lamps". (I will also be installing a universal turn signal switch assembly (Part# 53-551)) It sounds like for my application I will not be using the White Wire(22) for "Stop Lamps", so that leaves me with 3 wires to figure out how to connect to the tail lamps. Both the tail lamp assemblies have a Black and Yellow wire coming out of them. Can someone explain how I hook up the 3 new harness wires to the 4 tail lamp wires (2 black and 2 yellow)?
