| | | Forums66 Topics128,162 Posts1,056,933 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | Shouldn't be any problems with that conbination of parts. Your wil most likely need new motor mounts and a transmission mount, different driveshaft yoke or whole driveshaft, and better cooling system. You should think real hard about the brake system. You need to stop safely with the extra power you are adding. Plan on a dual mastercylinder at least if it doesn't have one now. Floor shifter or late model column shift? How is the rear axle geared? Sure a lot to think about, Joe. | | |
