| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Stock pistons! A.040" overbored 261 block and a 4 3/8" stroke comes out just a bit over 300 cubic inches. The crankpin size on the NASCAR rod is around 1 7/8", which allows a big offset from the original centerline. Total stroke change is 7/16". A standard bore 235 with original pistons, the same stroke increase and rods comes out at 266 cubic inches. The rod is a Carrillo tool steel item with a 6.450" center to center length. Jerry
