| | | Forums66 Topics128,078 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 11,063 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,063 | The bolts holding the inner fenders to kickboard on my truck were hex, and I'm pretty sure they were original. The LF fender was replaced but the right was original. But either slotted heads or hex can be ground off like you suggest. Much easier to work on stuck bolts when you're not laying on your back underneath or trying to squeeze under the dash.
