Yea folks, thanks for the help. It did end up being the shift level. The end had worn down to the point of getting caught between two gears. I had end welded to build it up, then shaped on the grinder - it now works great. Bob
I sure appreciate this forum - and your helping a rookie when it comes to trannys..
