1 members (baldeagle),
86
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Squirt a little oil on the pivot points for the pedal linkage, particularly the two loops on top of the bellhousing, and work the pedal several times with the battery disconnected. Also be sure the return spring is there and in good condition. Stuck switch contacts by themselves would keep the armature turning, but the starter drive gear should have disengaged from the flywheel if the linkage was not in a bind. Sagging motor mounts and/or cab mounts can also cause the starter linkage to bind on the body metal. Jerry
