| | | Forums66 Topics128,037 Posts1,055,463 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | An auto trans does not have a pilot bushing. The snout of the torque converter centers up in the large counterbore behind the bushing. On small block V8's, the automatic trans crankshafts have a smaller hole than the std. trans shafts, and if one of those shafts is used with a manual trans, a smaller OD pilot bushing must be used. It's possible that the late model sixes are the same way. To get the bushing out, just thread a 5/8" diameter tap into the bushing and keep turning once it bottoms out. The bushing will walk itself out of the crank. It ruins the bushing, but it's trashed anyway if the trans won't fit into it. If you have access to a good selection of chucking reamers, it would be possible to ream the existing bushing a few thousandths larger than the trans input shaft. Drill bits are not accurate enough to cut precision holes. Jerry
