| | | Forums66 Topics128,026 Posts1,055,399 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | "The ABC's of carburetion- - - - -Always Buy Carter!" That was Carter's slogan for many years, during the time they were selling a million replacement carbs for Rochester B's. Now, before you go to the extreme of swapping carbs, take the top off the Rochester and check the float. They're notorious for springing leaks and getting the hollow brass float about half full of gasoline. That allows fuel pump pressure to push the needle valve off its seat and cause a flooding condition at hot idle. Quite often, a simple float change will solve the problem, even without a complete carb rebuild. Be sure to set the float level and drop correctly before reassembling the carb. The chances that a replacement float will have the right settings are somewhere between slim and none. Jerry
