3 members (1955 1 Series, 2 invisible),
128
2
Mod | | | Forums66 Topics128,195 Posts1,057,370 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | Main problem with the swap will be motor mounts and radiator location. The 250 water pump will be quite a bit lower on the engine, this creates a problem with fan blades and lower radiator hose. Lowering the radiator isn't that hard, or you can use a late model electric fan, just don't tell anyone here you did!
Joe | | |
