| | | Forums66 Topics128,066 Posts1,055,875 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 102 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 102 | Thanks for the ideas! The crankshaft and the water pump both have 2 belt grooves, so a separate fan shaft may be fairly simple. I also read about someone using a cookie sheet for their fan shroud. It would be a good starting point.
Thanks for the shove in the right direction! Jon | | |
