Went to the shop this morning. Fellow asked if it was charged and I said only about 11.5 volts. He put his voltmeter on and found 11.8v.
Then he put on the load and the voltage dropped to 5 volts. It was the battery he says so I bought a new which I am trying to install but the hold down bracket goes right over the post location. Trying to move the threaded uprights ahead but its tough as there is not much room to swing a big hammer.
Once its in I'll let you all know.
I don't know if batteries are getting heavier or I am getting weaker.
"Sedgewick"
1949 Chevy 1/2-Ton
1989 Caprice
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
