| | | Forums66 Topics128,086 Posts1,056,098 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | How about just bending the pedal arm so it goes on the right side of the column. Or make a template out of say a metal rod or a piece of 1" flat stock to clear the column and locate the pedal pad at the desired location. Then you can remove the current pedal and have a shop make you up another one to bolt in.
I normally just bent the pedal over to clear the column.
Joe
