| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | I usually tighten the inner nut firmly, enough to require a little effort to turn the hub, then back off slightly until one of the lock ring tabs can be bent down to secure the nut. Then tighten the outer nut securely with a socket or a flat-tipped punch and bend a lock tab outward to retain its position. Jerry
