| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Saginaw steering on trucks up to one ton are common and be used with for and aft drag links and port and starboard drag link. Saginaw makes larger gear that are used on 1.5 to 3 ton trucks, larger, double steering gear with similar pump. Should work well with larger truck. Check midsize truck's gear for compatibility.
Probably would be better choice that trying to make antique steering system work.
Ed
'37 GMC T-18 w/ DD 4-53T, RTO-610, 6231 aux., '95 GMC running gear, full disc brakes, power steering, 22.5 wheels and tires. '47 GMC 1 ton w/ 302, NP-540, 4wd, full width Blazer front axle. '54 GMC 630 w/ 503 gasser, 5 speed, ex fire truck, shortened WB 4', install 8' bed. '55 GMC 370 w/270, 420 4 speed, grain, dump bed truck from ND. Works OK.
