| | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | My driver side vent window is missing the latch. It was missing it when I bought the truck. I don't want to replace the whole thing. ($268) I just want to add a handle back to the window. I purchased a replacement handle only to learn it does not come with the pin the goes through the glass the handle mounts to. Has anyone found a supplier that sells the entire latch assembly or have you made your own pin. I am thinking about pulling the one from the passenger side and tried to fabricate a replacement. I have not had much luck finding a donor truck that I could pull the vent window from. | | |
