| | | Forums66 Topics128,187 Posts1,057,312 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | I would guess it is a zero or 2 psi system, even my '37 was zero pressure. If it is clean and in good shape, it will cool just fine. The newer motor should not make anymore heat then the old one did. There are products like Water Wetter that help cooling systems work better in case you need it. | | |
