Engine stamped: F0909LK I assume this means Flint/Sept/9th. I am having difficulty with the LK. I believe it is out of a car, with manual transmission.
Also stamped was CON 2. H233. Is this a 1963 engine?
Any clarification is appreciated. I did not ask the seller if the engine was original to the car when I purchased it.
Thanks.
Revisit your "LK" Suffix code on the engine serial number...could the "LK" really be "LR"? If so, it's a 1964 230 w/3-speed manual transmission.
H233 is the Cast date code...Aug 23, 1963 which would be about right for a Sept 9th build for a new 1964 model year application.
Mike B
