| | | Forums66 Topics128,060 Posts1,055,839 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Are you using the original torque tube rear end? If so, you definitely need the crossmember and the mount assembly. That mount assembly supports the transmission torque ball assembly. The torque tube is heavy and the leaf springs put a lot of additional downward force at the torque ball area. Carl
