| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | That's just a very simple single contact relay. Since you're running 12 volts, just go to the corner parts store and buy a Ford-style 12 volt starter switch and wire it up to energize the starter-mounted solenoid. Use the "start" signal from the ignition switch to trigger the Ford switch. Jerry
