Has any one installed a SM 420 transmission in a short wheel base pick up such as a 1959 Chevy. If so what did you do about the drive shaft. I've got several SM 420's to pick from. Some with the four bolt flat universal set up with the brake band and others with the u-bolt universal joint hook up. Will I have to put in a hanger bearing? Thanks
