1 members (Hotrod Lincoln),
60
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The pump needs to be modified by pushing the fan hub back with a hydraulic press and cutting the shaft off a little. Some of the resto-ripoff places sell modified pumps for outrageous prices to people who can't do the press job themselves.
Once you get the fan and pulley pushed back to clear the radiator, you'll find that the fan will try to hit the harmonic balancer and it will be located too low to cool the engine properly. The fix is to purchase a pump relocation plate that allows the 54 and earlier water pump to be used on the post-55 block. That will put the fan in the proper location to cool properly, and fit far enough back to stay out of the radiator. Jerry
